Old Aug 28, 2015, 10:08 AM
Browse all: Engine
Repairing leaky valve seal?
Old Sep 19, 2009 | 12:04 PM
CKSMartin's Avatar
Default Repairing leaky valve seal?
Just wondering how complicated a repair like this is. I have a spurt fo smoke everytime I start the car (if it's been sitting for hours) and have decided it's a leaky valve seal.
My own mechanical skills normally are confined to everything OUTSIDE the engine. I've never done in repair of anythign inside the engine, but it seems to that it shouldn't be that much trouble. Remove the valve cover and do the repair?
I'm interested in learning more, but my main concern is there's something spring loaded, etc that will make this a too complicated repair for me and any repair manual I get.
Old Sep 19, 2009 | 05:01 PM
flyerI's Avatar
You are right; it doesn't appear that hard if you have the right tools. You need a fitting to put compressed air on the cylinder you are working on to hold the valve up. A Toyota mechanic friend of mine says it is simple but remember he does it every day. It's also easy if it is not yours and you have transportation for later in the day or the next morning. I have decided to let him do mine for me and I generally don't mind trying anything. It is usually determined by how much time I have. BUT, I have towed a car to a shop after I started working on it and found myself over my head from a tool and equipment position.
Old Oct 10, 2009 | 11:47 PM
namesbs's Avatar
Ya, it's not a hard repair at all. Get a leakdown test kit to keep pressure on valves and then just take off the top timing cover to expose the gears. Make some paint marks for timing purposes and then take off the belt and cam pulleys. Put a small screw into the sprung cam gear(s) and then remove the cams. Remove the valve buckets and use a magnetic spark plug socket to put over the valve spring keepers and hit it with a hammer. Remove al hardware and the seal is at the bottom. You may need to buy a special set of pliers if you dont have them allready to remove the seals. To reassemble valve springs there is also a special tool to drive the keepers back into the hat. All else remains just reversed. Besides the few special tools, not too hard of a job or complicated.
Old Oct 11, 2009 | 05:19 PM
honda pc's Avatar
how much does a repair like complete valve seal job cost on a 96 camry 4 cyclinder. average shop cost, from toyota dealer to independent shops.
And does the repair fix the problem and how long will it last before smoking again because of leaky valve seal. Another words.. how long will the new seals last bofore leaking again.
Old Oct 11, 2009 | 07:15 PM
flyerI's Avatar
I have not done this on my Camry but need to do so. I haven't priced it because a friend usually helps me with most repairs and it just costs me dealer prices for parts. I would look locally for an independent import repair shop. That will get you the best price in most cases. I would be surprised if an independent charged more than $200 for the job. Post what prices you find. And yes that should solve the smoke at start up.
Racprops
May 20, 2015 02:24 AM
valveguy
Jun 2, 2010 12:34 PM
speedfreak87
Dec 26, 2007 11:40 PM
jaybird
Jul 23, 2006 07:58 PM
aussiejo
Jan 25, 2006 08:18 PM
