Difficulty Of Front Brake Job?
Old May 31, 2009 | 01:58 PM
demiandvm54's Avatar
Default Difficulty Of Front Brake Job?
Hello:
Newbie here to ask the establishment about the difficulty of doing a front brake job on a 2003 Camry XLE, 4 cyl. I have performed brake jobs before on Fords, GM, vehicles. Should new rotors always be used with new pads? I previously measured the rotors with a micrometer to check them for thickness. How hard is rotor removal, must the spindle be removed? ( I have not looked at the car yet) Any info or tips would be appreciated. Are ceramic pads worth the extra cost? Thank You!
Michael
Old Jun 17, 2009 | 02:11 PM
turtle02909's Avatar
Default Brakes
It all depends on how many mile u have driven the car and how often u use the car for work and so on. For example my 07 camry Le I have brought brand spankin new from the dealer with 0 miles and now I have 53000 miles on it and It was my daily driver and I had brake pulsating at highway speed. I decided to changed all four rotor and brake pads at 53000 miles and not worry about it until 100600 miles later. I did the work myself.
Old Jun 19, 2009 | 02:48 PM
05cam's Avatar
they are pretty str8 forward...Brakes are a walk on the part on most camrys, rotors shouldnt be to bad either, i replaced them on my 05 le at 80k or so, just have to remove the brake caliper and bracket, rotor should just fall off then.
jebra
Sep 2, 2010 07:54 PM
dan
May 20, 2010 06:54 PM
dsmith222
Oct 23, 2009 10:03 PM
acs1123
Oct 23, 2008 05:35 PM
wildmonk
Aug 14, 2008 08:39 PM
