1995 Camry left axle stuck
Old Dec 16, 2008 | 05:01 PM
cnewt15's Avatar
Default 1995 Camry left axle stuck
My Camry had clicking issues in the front end. I replaced both front CV axles, the right side was brand new, the left was a remanufactured unit. The left side clicks still, since the reman unit is bad. the problem i am having, is the axle i put in, i cant get back out to replace it. I have tried every pry bar i can find. The original popped right out. Now the replacement wont budge. It still has play in it where you can slide it in and out slightly, but I cant seem to jerk it out. Does anyone know any secrets? or ideas?
Old Dec 16, 2008 | 05:16 PM
cnewt15's Avatar
Default RE: 1995 Camry left axle stuck
Sorry if i left out some info, but it is a 1995 4 cyl Automatic
Old Dec 16, 2008 | 06:22 PM
I assume left side is drivers side. C-clip split should have been facing down when installed, although I can't say that's your problem. On my 95 I eventually had to use a 3 foot pry bar from above through hood opening with a piece of metal used as fulcrum against the engine. Unit popped with a snap! Don't be afraid to use force. I'd advise using a new c-clip.
Old Dec 17, 2008 | 07:31 PM
cnewt15's Avatar
thanks Pedro. I finally got it. I had to use a 5 lb slide hammer, but it came off the first pop. Then went back together in less than 30 mins. Working fine. thanks again for the info. i am a new Camry owner, my first Toyota. I will be back here frequently.
Old Aug 20, 2010 | 09:08 PM
thedude's Avatar
I found that after struggling for two days to pry it out from underneath, removing the rubber air intake boot as well as the resonator and using a 36 inch pry bar from Sears makes the driver's side axle come out delightfully easy. I also used the big pry bar from above method with about a 1.5 inch thick wood block to seat the new axle.
CDG
Jul 21, 2012 01:39 PM
ctullar
Dec 5, 2010 07:25 PM
black_manta
Apr 16, 2008 01:13 PM
ter
Aug 8, 2007 05:53 AM
upjeeper
Oct 10, 2006 06:14 PM
