2005 power door locks
Old Jun 12, 2008 | 10:23 AM
ambarr@pcbc.org's Avatar
Default 2005 power door locks
Drivers door unlocks every time using both keyless remote and door key, all other doors will not unlock electronically. However, all doors will lock using keyless remote, door key, and when the car is placed in gear. The problem used to be intermittant, now works properly onlyabout 1 out of 100 times. Drivers doorunlock switchonly unlocks drivers door, all other doors are unaffected.
Old Jun 17, 2008 | 08:33 PM
Default RE: 2005 power door locks
Typically would state to check the wiring between the drivers door and chassis as over time they can become damaged due to door usage. However these newer locking systems can be programmed, perhaps it needs reprogramming.
Old Jul 22, 2008 | 12:42 AM
hieply's Avatar
I have the same identical issue with my 2005 camry LE. Were you able to fix the issue with your camry locks?
Old Mar 19, 2009 | 07:11 PM
JDubya's Avatar
Bump..
Any info I have the same trouble w and 2004 SE. Any direction would be appricated..
Old Mar 29, 2009 | 07:34 AM
vnvnvn2000's Avatar
I just got done searching some other sites and found the answer to my problem with the door locks.
I just went out and replaced the IOD fuse. It was a 20 amp fuse. All of the lock features work again!
Good luck with yours!
Old Jun 13, 2010 | 10:14 PM
holzhben's Avatar
I am having the same lock problems. Where is the IOD fuse located? I looked in the panel under the steering wheel and the panel under the hood. Are there any other fuse panels?
gazpazr123
Apr 30, 2014 09:35 PM
charlene
Jun 25, 2008 09:47 AM
goobee
Dec 25, 2007 12:34 PM
lorenzo01
Dec 8, 2007 08:36 PM
josephpatrickgray
Jan 25, 2006 08:30 PM
