Old Sep 1, 2015, 03:40 PM
Browse all: Steering & Suspension Guides
Steering Wheel Vibration
Old Jul 16, 2007 | 11:14 AM
camryowner98's Avatar
Default Steering Wheel Vibration
Hi Everyone,
Am a new member and would appreciate your help/recommendation to fix my steering wheel vibration on 100 Kph (+/-60 Mph). I also noticed that the body vibrates on 100 kph. Ibalanced the tire pressure and still the steering wheel vibrates. 1998 Toyota Camry LE 4 cyl
Old Jul 16, 2007 | 11:17 AM
Default RE: Steering Wheel Vibration
The vehicle is 1998 Toyota Camry LE 4 cyl
Old Jul 17, 2007 | 10:24 AM
its good that you balanced the tire pressure but it sounds to me as if the wheels themselves maybe off balance. depending on where you bought your tires from, you may have lifetime balancing included so take them back to where you got them or a new place and get them balanced. If that doesnt solve the problem then you're going to have to look into more expensive repair options.
good luck, and i honestly think its just the tires being out of balance. And have them re-check and adjust tire pressure while they're at it.
Old Jul 17, 2007 | 06:04 PM
Thanks for your recommendation. Am living in Toronto, Canada and I bought my set of tires sometime in Sep 2006 in Tampa, Florida. I took my tires to 3 different Toyota delearships in Toronto to balance my tires and still the same result (steering wheel vibration).Am just assuming that if the tires are properly balanced the rims arebasically OK.Recommended tire pressure is 30 at the front and 29 at the rear. Few months back, I was using the 4 set of winter tires and I don't have the steering wheel vibration. Am I wrong to assume that I should replace my 4 all season tires I bought from Florida? Would appreciate your comments...thanks
Old Jul 17, 2007 | 07:21 PM
the wheels themselves maybe bad. You could try to see if u can get a warranty replacement from either the manufacturer or the place in FL that you got them from...
Old Jul 18, 2007 | 10:12 PM
Thanks again for your recommendation. I am considering buying new 4 sets of tires. I will update youwith the resultonce I change to new set of tires.
Old Oct 2, 2009 | 02:24 PM
laredoggg's Avatar
all these shaking problems on the camrys cant be all tires. there must be another issue ? wheel bearings or controls arms.
turboxb9s
Mar 27, 2022 04:41 AM
Swift101
Jun 17, 2013 08:58 AM
06CamChic
Feb 19, 2010 09:55 AM
michael
Sep 23, 2005 04:36 PM
Dan_Lemur
Jul 6, 2005 02:20 AM
