Old Aug 28, 2015, 11:23 AM
Browse all: Wheels and Tires
2003 Camry 4th set tires & only 86k miles! Anybody else with this problem???
Old Sep 10, 2008 | 12:20 AM
  #11
full house's Avatar
Default RE: 2003 Camry 4th set tires & only 86k miles! Anybody else with this problem???
what kind of tires you have? Do you mind to share some pics?
Old Sep 19, 2008 | 01:52 PM
  #12
PyrMan3's Avatar
Its your alingment, im telling you right off off the back, i may not know what may have the caused the problem, but try running, 35 lbs of pressure, sounds like eyou have a positive camber problem, where are you located? i may beable to help you fix it? Do you have alot of potholes? that may just be the case and may have bent up your suspension, the garages never want to admit their faults,
post some pics of the tires and i could help you from there
Old Nov 28, 2008 | 02:49 PM
  #13
goat_floats's Avatar
i had the same problem on my 97. on the second set of tires i took it in and got a four wheel alignment. that solved the problem.
Old Dec 1, 2008 | 11:34 PM
  #14
sn4eva's Avatar
i ve got an 06 with 17s also with 76k on them on my second set of dunlaps and the first set was the factory turanza el42 that gave out at like 40k i think so i think it might be your car
Old Apr 7, 2010 | 07:53 AM
  #15
mogre's Avatar
Default 2003 Camry goes thru tires
Yes, my 45000 rated Dunlops are bald at 33000!
Old Apr 7, 2010 | 07:56 AM
  #16
mogre's Avatar
My car is dealer serviced every 3000 miles, they did alignments as required, the tires are not under-inflated. 35 PSI is NOT the manufacturer's spec. I was complaining I thought it was the Dunlops, what else are they selling, but if it's the car, then Toyota owes me a tire discount, not Dunlop.
Old Aug 21, 2015 | 02:38 PM
  #17
JAB's Avatar
JAB
Hey ginakins77, I think it is a car problem. Happening to too many for it not to be. I have and 02 Camry SE and an 2012 XLE hybrid. The XLE has only 30k on the tires and front are shot. Has been serviced by dealer and rotated regularly. The 02 went through tires ever 25K or so. So, this will be my last Toyota. When you look around this has been a problem for a long time and Toyota has not addressed the issue. Think I will go back to Honda or Nissan.
Hkybob
Dec 10, 2014 04:35 PM
photo2u
Apr 2, 2012 12:48 AM
larrys
Sep 10, 2011 10:14 PM
albert101
Jan 17, 2008 10:32 AM
hoangkb
Jul 24, 2007 10:08 PM
