Camry Forums
Toyota Camry
Camry Forum
Camry Forums - Photo Galleries - Create an Account
Go Back   Camry Forums - Toyota Camry Enthusiast Forum > General Toyota Camry Forums > DIY - Do It Yourself
Thread Tools Search this Thread
Old 10-23-2009, 04:14 PM
chips19023 chips19023 is offline
Unhappy 2000 Camry P0305 Error Code
Hi, I am getting a P0305 code on mt 2000 Camry 6 cyl engine, It's a misfire on cyl. 5, I have changed the wires and checked the plugs which are good. the car has 52000 miles on it. Does anyone know which Cyl # 5 is. can anybody help.
Thanks
Chips19023
This ad is not displayed to registered members.
Register your free account today and become a member on Camryforums!
Old 11-01-2009, 01:41 PM
namesbs namesbs is offline
Cylinder # 5 is the cylinder closest to the left side of the vehicle that is in the rear bank underneath the plennum. Misfires can be caused by may things (plug, wire, fuel, compression, etc...). Check for injector operation and swap the plug from #5 to #3 and see if the miss is still coming from #5 or not. If it misfires in #3, it's the plug. If it stays in #5 than it's a problem with the injector or the compression.
Old 11-03-2009, 02:08 AM
Joel_CA Joel_CA is offline
You're coil is more likely the suspect over an injector and is easier to test for. Swap coil that fires #5 cylinder with one of the neighboring coils and drive the vehicle until the check engine light comes on again. If the misfire code follows the coil- then you have a bad coil. This is by far the most common cause of misfire on the Camry V6.
JJ
__________________
Certified Toyota Technician
Old 11-03-2009, 09:13 PM
full house full house is offline
Is that a misfire? P0305 Code - Cylinder #5 Misfire, A P0305 code means that the the car's computer has detected that one of the engine's cylinders is not firing properly.
I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
Old 11-07-2009, 10:52 AM
Default Code P0305
Hi Again, I switched coils as recomended, I switched the center coil with the right side coil, Ran the car for a week before I got a bad code, Now the code is P0302 which is Cyl # 2, I don't know the firing order of this engine, I am guessing that the coil I put in the center position is the bad one? Does anyone know which coil fires which Cyl.
Thanks
Chips19023
Old 11-08-2009, 02:14 PM
#2 is on the front bank and is the coil that is closest to the passenger side. I'm not quite sure where you swapped the coil to, but if you moved it to #2, then you need to replace the coil.
Old 11-09-2009, 11:32 AM
I swaped the center coil with the one to the right of center, The one on the drivers side. Now I get a P0302 error which makes no sense to me, it was cyl # 5 now its cyl # 2, Does anyone know what coil fires what cyl.
thanks
chips19023
Old 11-10-2009, 12:16 AM
glenfoxman glenfoxman is offline
Send a message via ICQ to glenfoxman
Default 2000 Camry P0305 Error Code
f i were to bolt on one of these turbo kits to my stock engine that currently has 221000 miles on it what do you think the chances are of it blowing up? what will i have to upgrade, if anything?thanks doug _______________________________________Website I designed for no fax payday loan company.
Tags
camry, code, coil, error, misfire, p0305, po305, toyota, v6
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
